Rear tire carrier that swings with tailgate
Swing low sweet cherry pie
Rampage make one too, although I've never seen it in person.
Rampage Products 86606 - Rampage Products Rear Recovery Bumper with Tire Carrier for 07-13 Jeep® Wrangler & Wrangler Unlimited JK - Quadratec
Rampage Page 17
If you want to tow you will have to get the Rampage receiver because the factory one won't work.
I thought I wanted my swing-out attached to the gate last year when I started looking for bumpers. Then I thought of how much convenience am I really buying? I ended up getting the non-attached type and like it just fine. The fact that I only paid $785 for the tire carrier, rear bumper AND front bumper was another reason. I did incur the additional cost of moving my license plate (and 3rd brake light) to the spare because the swing-out latch covered part of the plate. (I had to do something with the 3rd brake light anyway with bigger tire... bigger tire coming next week. Original tire in the picture.)
Rampage Page 17
I have the teraflex hinged/adjustable tire carrier. MSRP is around $700 I think, but hit up David at Northridge and he can hook you up with a better price. I've been really happy with it so far. Also gives you a little more flexibility as to which rear bumper you go with.
ACE rear bumper and tire carrier is exactly what you described. I have had it for a few months now and love it. Super easy to install and great customer service.
The less expensive bumper is less expensive due to design. That swing arm clamps onto a surface bead welded spindle by two bolts. No bearings, just a pressure collar. So what's holding that spindle is a circle weld. That spindle is only 4" high with all the torque around a circle weld on the surface of the bumper. When you hold a bat, do you just use your index finger wrapped around the base, or two hands? Also what keeps the swing arm from jumping off is a 1/4x 3" bolt. Not sure how much abuse those threads can take if your wheel hits a ledge. I don't mind their bumper, my concern is how the spindle is attached.
Just my opinion, but I appreciate good design. If I spent double, I would've purchased Expedition One.
Attachment 469742
Best Top High Rock bumper and single action tire carrier. It has carried a 35" for 2 years. The spindle is firmly attached and braced the height of the bumper; the nut holding the swing arm is a 35mm axel type with cotter pin; bearings; it is serviceable with a zerk; includes CHML. " Quad " has it listed for $700 but that has to be a typo.
There are less expensive, but that option has the spindle only surface welded. Think of holding a baseball bat with your forefinger wrapped around the base and pushing the top of the bat: the same force a swing arm with 100 lbs. of wheel on it.
X2 on this bumper/tire carrier.
I am also very happy with it.
X2 on this bumper. Just installed mine and I love it. If you get it without the Rigid SR lights, then I think its within your price range. I think the quality is top notch, and it's 1/4" steel. Can't go wrong with this choice IMO.
