Rear Swaybar
I'm wondering how many people run without there rear swaybar? This last weekend I found the rear swaybar was restricting my CO's to work properly so I removed the swaybar. Driving on the road, I can't tell a difference and droop on the rear axle dropped further per measurement.
After adding RK rear control arms it pushed my axle back to where the sway bar links were contacting the upper control arm mount. I had planned to move the sway bar back, but when removing it i ended up busting off two or three of the bolts so i left the thing off.
After running without it the only difference i see is offroad, making my shocks my limiting factor so if i droop too much i couls lose a coil..
On road no difference really.
Front is a must. Going down 168 from Shaver with no rear tracbar didn't even feel a difference.
