Rear Sway bar, run it or pitch it?
I have a 2012 4 door Rub, 3 " lift, 35s. I have ran with the rear sway bar on and off a couple of times as I'm always changing something back there.
Removing it will loosen up the ride slightly in the city making it more comfortable when cross threading over some rough pavement ect. Smoother off
road for sure. It I was commuting daily at speed, 70+, I would leave it on for a little less body roll. The majority of people would not notice the difference if
someone stole their rear sway bar in the middle of the night. It is noticable, but nothing like hitting the disconnect switch on the front.
SG
I attached one of my latest Mcguyvers. No more track bar.
SG
There was a picture around here somewhere showing a damaged rear axle which was caused due to the sway bar having been disconnected. During extreme articulation apparently the shock broke, which was the only thing holding up the axle. This in turn caused the spring to fall off, the brake line to burst, and the drive shaft to break as well.
EDIT: Found it, on this thread: https://www.jk-forum.com/forums/modi...ay-bar-140365/
No issues here with out rear sway
Sponsoring Vendor
It appears the shock or shock mount broke - Without the sway bar the full extension of the shock is the down travel limit, same as the front. If the front shock broke, the same damage would happen (Brake Line, ABS, Possibly Drive Shaft, and Spring fall out).
SG
I attached one of my latest Mcguyvers. No more track bar.Attachment 400405
SG
very interesting...
Gotta say here, if a representative from Offroad Evolution says not to do it, I'm going to listen. They have quite a bit more experience in this area than most of us. I wouldn't do it.
exactly, that's why I put up the Link with Wayalife etc saying the exact same thing. With the experience and r&d testing these guys have been involved in, gotta say they do have the most valid view on these topics.
