rear sway bar options
1 Post
Looking to add the Synergy upper shock mounts in the rear and they put the shock right where the factory sway bar is. I'm also looking for a stiffer option but one that will flex well off road. It looks like Currie makes an anti-rock that is stiffer but its got the aluminum arms and is pricey. are there other options for just a factory replacement that is stiffer?
Call Synergy. They likely know about the many ways customers have made it work. They're good people there and will be helpful.
running the lower mounts and the uppers.
I use the stock sway bar. All you have to do is move your sway bar mounts on the frame back about 2 inches.
Former Vendor
We sell both, and components from Currie. Give me a shout if you have any questions!
Synergy 8086 JK Rear Upper LT Shock Mounts | Offroad Elements
Currie Enterprises Rear Antirock Sway Bar Kit | Offroad Elements
