Rear Suspension Diagram
I have seen the Project JK diagram for the front suspension components, does anyone have a picture that points out all the rear components? I realize they are the same components, but the locations seem different. Starting my TF 2.5 Coil install this weekend and the first step is to loosen all control arms. I can find all the ones on the front but just making sure I have the rear correct.
***EDIT*** I have everything I need, just need to know the following:
Does loosing the control arms need to be done before jacking it up? Seems that it would be easier to jack, then loosen, as the wheel is in the way. TF only mentions the 21mm bolts, so I am assuming they just want you to loosen the lower control arms during that step, or do you need to loosen the uppers as well?
Well, a 21mm socket will loosen the following components hardware.
Front Track Bar
Front Lower Control Arms
Rear Lower Control Arms
Rear Upper Control Arms
Rear Track Bar
You got alot of bang for you buck with a Jeep owning a 21mm socket! LOL...
Rock Krawler
Front Track Bar
Rear Track Bar
Rock Krawler
