rear springs bending...help fix
thanks for the quick responses everybody. i will look into the brackets, since i dont plan on changing my lift at all should i just cut the old perches off and weld the new ones on? or is the bolt up versions better? and where did you get the spring retainers Renpia?
Do a search for Spring Retainers. There are a few manufacturer's for rears. I only found one available for the front when I was looking for them last year. I forget the brand I bought, sorry. Do a search, I'm sure it will come up or there may be more options available by now.
I run the rk wedges. They definitely help ALOT with the spring bow. The only way to get the springs "perfect" is with new perches like the ones jks and teraflex make. But for $25 u can't beat the rk wedges!!!!
Jks also makes rear lower retainers. Currie makes upper and lower but more $$, and u can't run a spacer with them if u needed to for weight/sag.
