rear spring shifted out of place - is this common?
#61
I'm hoping TF addresses the issue for future buyers with shorter shocks for this kit. I don't like the idea of adding a spacer to the back to prevent the coil from falling out. Even with the spacer I think the whole setup will still move around under full extension... that concerns me
#62
Although, there really should be some clips to hold the spring in place.
#63
#64
To answer your question, yes the kit should come with the spacer/spring guide. But as to weather or not TF should send them out free of charge to everyone......i am not sure. I mean all the 07-08 JK owners like the little net thing on the center colum and the revised hard top brackets, but should chrysler have to provide those to every JK owner in the world that didnt get them????? I know I am going to get some flack for this, but my opinion is to find the date that they "became" a part of the kit, anyone that purchased a kit packaged after that date should recieve them for free (with proof of purchase obviously) and everyone that got a kit packaged before them should have to buy them.
#65
Ok, so I am coming in way late here, and I did not read every post. But...
You should NEVER use shocks to limit articulation. If you need to limit droop, get some straps, if you need to limit compression, get longer bump stops. The purpose of a shock is not to limit articulation, and if you use it for that, you will just end up with some broken shocks.
Spring straps don't "hard limit" droop either they just keep the coils in place, the stetching effect of the spring would take any thump out of the bottom limit and I actually think that is a good thing but still in the end there has to be some hard limit before your tailshaft gets pulled in 2 or brakelines ripped out.
Possibly you mean real axle limiting straps that actually are loops passing under the axle up to the chassis?
We have to remember here these are coil springs, leaf springs self limit travel.
Personally I suspect coils should be solidly attached at both ends so they can handle being stretched as much as they are compressed, because then you could get a vehicle with a lot more travel but still not need ing to be jacked up into the sky in height, so keep the centre of gravity low and cop attention to a minimum while still acheiving good flex.
#66
If all JK factory coils prings were falling out like this and the fix was to replace the coils or just add spacers, yes I think CJ should bear the responsibility to do so for all vehicles produced, and I suspect that Terraflex would supply free the spacers too any who had previous kits that require them as it is clearly something they should have found when the test vehicle was tested before selling this kit as a production item.
#67
The spring guides will allow for more droop, as the spring will be allowed to drop below the spring bucket. However, if your shocks are bottoming out, a limiting strap should be added to stop the axle just short of bottoming out the shock. This will prevent you from damaging the shock, which can and will happen if you consistantly bottom out the shock.
#68
Hi All,
Maybe this is a dumb question but... what limits articulationin a stock rubicon? I saw no limiting straps or retainers last time I was under there. They would be nice to have and they surely makes sense, but it appears that the stocker and most 2.5 coil lifts rely on the shock to do this.
If some company starts making limiting straps to go along with their 2.5 coil kits I would probably buy them.
#69
Hi All,
#70
Hi All,
I suspect coils springs seem to be a new thing over there, us Aussies have been serious into coils since the coil sprung Patrols and Landcruisers hit the market in the late 80's.
