rear spring shifted out of place - is this common?
#101
Teraflex 2.5" Coil Lift
#102
I have never seen or heard of a rear trackbar re-local bracket on the passenger/right side of the vehicle This just goes against all common sense, maybe the people @ TF or the people who installed the lift are aliens and our laws of physics do not apply
#103
???? I've seen the rear brackets on the drivers side (tube) busted off. The brackets on the passenger side (frame) typically hold up.
#104
TF has a bracket for the trackbar that attaches to the frame on the passenger side and is designed to help
keep the TB more level or horizontal.
But, talking with TF, it is really not needed if an adjustable TB is used.
#105
Images of TF "passenger/right side" relocation bracket can be found here ---> https://www.jk-forum.com/forums/show...920#post695920
#106
TeraFlex:
BDS:
Rough Country:
#107
I didn't see that info (trackbar relocation kit) on the first posts and it would definitely correct any angle distortion probs as long as it was specific to the lift.
Hope I didn't confuse the whole matter, just trying to help from a different angle.
Good luck.
Good luck.
#108
I'm really leaning towards shorter rear shocks as a solution... I just saw first hand with the Jeep up on a lift how much space there is between the factory isolator and the spring bucket and it's much more than 1/2". I just think these 28" extended 9550 shocks are too long for this application and I could still see the potential for that spring to move around even with the 1/2" spacer. As far as using the Currie spring retainer I think you be asking too much of it on both the top and bottom to keep that spring in tact. It would be "stretching" that rear spring at least a few inches under full extension and that's a lot of pressure on both ends of the spring retainers.
Here's what the rear coils look like with the Jeep up on a lift and also what we had to do to keep the coils straight as we lowered the Jeep off the lift since the coils were not contacting the spring buckets...
#109
Currie Rear Coil Retainer Update
Only kit #1251000 (2.5"-4 coils and 4 TeraFlex shocks) will need/have the 1/2" spacers that have coil guide (about 4" long). The coil guides are used to guide the coil back to their seated position. The TeraFlex shocks are 2.59" (rear) and 1.89" (front) longer than stock shocks with 2.5" extensions.
So if you have a 2.5" coil kit with shock extensions, your fine.
These were needed to address the issue noted in this thread - extra long TeraFlex 9550 shocks (for the 4" coil kits) being packaged with the TF 2.5" coil kit thereby allowing greater droop than the 2.5" coil could handle, occasionally resulting in dislocation of the coil. All is good now.
#110
Have had my Currie Rear Coil Retainers installed for some time now, but never posted a pic or an update. Basically, they have performed as intended. No coils flopping out while flexing on the trails with my long Teraflex 9550 shocks.
Good to know JK-Rubi. Thanks for posting your solution. I opted for shorter shocks to avoid adding that spacer/coil retainer that now comes with the kit.
