Rear Shock Rubbing Brake Line
Rotated my tires and installed my TF disconnects today. Was greasing up the rear links and found that the right side flex line is rubbing on the shock housing. Its enough to take some of the paint off and a mark is visible. The left rear seems to have plenty of room and is not rubbing, but the right side has as distinct 'S' shape. Lightly bent the hard line bracket and moved the brake hose away from the shock, anyone else have this issue with rear brake lines and/or the relocation brackets?
FYI
*The rear brackets are not backwards and no
I have not had the brake caliper off, so the lines are not twisted*
FYI
I took a short piece of rubber hose that had a hole the size of the outside diametef of the break line. Slit the hose and put it around the break line and then put about three zip ties around the outside of the rubber hose. I have had this on my JK since 2007 with no problems.....and it is a dirt cheap fix.
I thought about that fix when I had it in the air today but could only find a bit of coolant hose, too big of a diameter. Thanks for the info and looks like I'll be back under it tomorrow. Nice that it's raining out, NO yardwork...all JEEPWORK!!
FYI
FYI
Originally Posted by Youri
How do you keep your suspension so clean, slvr07.
