Rear shock looseness
Old 02-11-2022 | 12:33 PM
socksick's Avatar
Default Rear shock looseness
Hi, I installed New Fox performance shocks on my 2015 JK unlimited. And the rear bolts on both sides are very loose. I've torqued the bolts to the correct spec but the shocks are still moving.
I bought the jeep used so I'm not sure if the previous owner bent the brackets out. Should I just hammer the bracket to make it tighter? Or just use an impact and try to tighten the bolts more?
Old 02-11-2022 | 12:34 PM
socksick's Avatar
Any advice is appreciated.
Old 02-12-2022 | 08:10 AM
TheDirtman's Avatar
just tighten it down more.
Old 02-12-2022 | 10:44 AM
Sixty4x4's Avatar
That left side looks splayed out in the picture. What Dirtman says but take the nut off and add a little bit of anti-seize on the thread as a lube.
Old 02-15-2022 | 09:52 AM
socksick's Avatar
I just tightened it with an impact and put anti-seize on as well. My torque wrench was useless so I just kind of visually guessed on how tight it should be.
