Rear seay bar link ibstall issue
Bent a stock sway bar so I order some adjustables, they say to mount outboard of bracket and axle but if I do that they hit the tire. Inside I'm afraid they will hit the brake line even though it's kinda out of the way. Does it matter if they are mounted on the inside?
^ inside away from tire.
^ this one isn't tightened but is pushed all the way on. If the when the track bar moves up with flex it will obviously rub the tire extensively.
wow my spelling from the phone was horrible.(sorry) Anyways after further searching on my computer it seems to be ok to run them on the inside. After looking at it again I dont think it will flex high enough to hit the brake line, and if it does it should just glance off of it.
