Rear Seat Belt Idea (4 door).
Ditto, to that. I couldnt live with my self if my idea got them hurt. The only true fix is to send them to a shop and have the belt replaced with a longer belt. Or redo your cage and move the attachment points. Which would cost less? Well the seat belt webbing is about 50-70 cent a foot so id say a shop would do it for about 75-100 dollors time and labor. Call your local seam shop that does custom auto tops and seats. I bet they can hook you up.
tell ya what, since you seem to be stuck on this idea, go ahead, modify seatbelts that are a safety feature. when you wreck and your backseat passengers are killed because you modified the seatbelts to a less sturdy location, lets see what you say then.
are you an engineer? do you carry an engineering degree? do you know the psychics behind all the stress points, load ranges, angles for the locking mechanism, speeds and forces at which parts need to engage? see where i am going with this. im sure it can get annoying, but i would hate to see anyone in our jeep community kill someone over a mod. plus if you live the accident, not only will you have to mentally live with this for the rest of your life, but you will be held legally liable and charges of criminal negligence and civil will most likely be brought up against you. like a few others have said, this is a bad idea.
dude, just leave it alone. have you thought about maybe you have a problem with the ratchets? have you lubed anything up? i do not have this problem with mine, then again maybe mine are the ones messed up if mine ARE NOT doing this. i have had 300 lb men in the rear seat and zero issues. so maybe mine are messed up then. i will look into mine.
Note: Pic is after flash flooding caught us on day four of a Ouachita Trail backpacking trip. I agree, though, I wouldn't modify the back seatbelts.
I agree that I hate them being where they, and think they could have been designed better, but I would never think about moving them or modding them... Just wouldn't be safe. I was thinking of a clip or a velcro strap to hold the sholder piece down to the sholder of the back seats... My "little" (he is 29) brother is the only one who really rides back there from time to time and I know the strap rubs his neck but have not heard him complain about it locking up.
I'm 6'3" 250 and rode in the back of mine for the first time the other day. It locked up as soon as it buckled. I realized it was because I pulled it out too far to buckle it. It worked fine as long as I sat completely still and didn't lean forward more than an inch or two. It was a pain in the arse to say the least. I don't consider it an issue because my kids are the main backseat riders and it doesn't seem to do it too them. My wife does all her backseat driving from right next to me in the passenger seat so it is a moot point with her too! I am not a rotund man either. I agree that the belt itself is just a tad too short for most above average size people and that causes it to go into the lockup mode.
OK, I still don't get it.
I just went outside to understand what is being reported.
My outboard rear belts don't go into ALR mode until I'm within about 6 inches of the end of the belt.
I'm 6'3" and 240 pounds, so I'm not a small guy.
With the buckle engaged and belt around my hips, I have to pull the shoulder portion almost to the back of the front seat before ALR mode engages.
Unless Chrysler shortened the belts for everything but my '08 Unlimited, I'm not seeing the problem.
Are you sure the anchor portion beside the seat is properly routed? It's easy for it to get twisted and stuck behind the seat back, which shortens it up quite a bit.
I know my belts are routed correctly, but maybe there is a difference in year models. Mine is a 2010. I don't think its that big of a deal. But, kids and teens are the usual passengers 99% of the time. The things flapping in the wind with the top off is more of a pain to me, but that was an easy fix.
An, as for changing the belt out for a longer belt. That is totally safe. The places that make custom stuff have the right tools to make it right. No danger with this as the webbing is way stronger then youll ever need, and your not changing any of its design features. I think if they can sew up a harness for you butt to hang on the side of a rock, Id say I trust my life in them in a jeep.
Did you actually read the damn post? Apparently not. I was asking if it has been done. I was asking if anyone has thought about something other than a crap ass potato chip clip (no offense. It's a good idea just not for me). I've read the other threads and the only solution has been the clip. It's like apple's solution to the crappy reception on the Iphone. A case won't help a damn bit. They should have put more thought into the engineering and design of the damn thing. Not say We're sorry. Here's a free case.
I'm not one to use "home Depot" mods on anything important to the vehicle. Did you notice that this isn't the show and tell section? Did you notice that the pictures that I posted were HORRIBLY photoshopped for a reason?
I don't know why you jumped my ass in the first place. You asked what I was trying to accomplish and I responded.
If the side of the rear seat isn't good for the belt then why is the middle? Most rear seats are just made up of sheet metal with re enforcements to make it sturdy enough to hold the avg person. I've seen the inside of most vehicles. I Know.
If the seat isn't able to withstand the forces then WHY would Jeep use one connected to the seat?
It is the same belt as the 2dr. Haha, I get a kick out of them. Every time i ride in the back I fall asleep and they seem to hold me up haha.
I would rather change out the OEM belt for a longer one than cut up a perfectly good seat.
I can appreciate your aggravation.
