Rear seat belt help
Old 07-30-2012 | 02:57 PM
EpicMedic's Avatar
Default Rear seat belt help
I'm getting line-x put into my jeep next week and need to strip the tub so I can get a cheaper price. The carpet seems easy enough to take out but I'm having problems taking out the rear seat belts. How do you go about taking them out?
Old 07-30-2012 | 06:03 PM
Earth Siege's Avatar
I had hell with mine. Takes a metric torx. I used standard torkx and sheared out the torx teeth . Had to weld a 9/16 nut on the end and use an impact since they are locktighted in place. I went to fastenall and got replacement fine threaded shouldered bolts with a regular head on them i think it was 15mm but cant remember. Had to buy a bag of ten.
Were i to do it over again i would just leave them be and cover them up so as not to get bedliner on them. Was not worth all the mess of fixing the removal.
Old 07-31-2012 | 07:16 PM
BombJock's Avatar
What year Jeep do you have?
I have a 2011. I believe I used an 18mm socket (no torx) and breaker bar.
Tried using just a ratchet at first, but had to go to the breaker bar.
Good luck.
Old 07-31-2012 | 11:00 PM
My jeep is an 09 jkur
