Rear Pinion Angle
The best response i have found is make sure your pinion is at the same angle as your DS for a stock shaft. Within a deg or two of it at least and should be fine....unless someone can counter that (please due i am still learning) i am running with that
Going out on a limb here but if you have a teraflex lift and are installing teraflex rear upper control arms I bet if you reach out to them they can give you an estimate of how long to make your arms so that your joint lines up straight with your shaft (ok that sounded a little gay but whatever ). They have some pretty good customer service over there. When you find out please post cause im curious as well
It has diagrams in the tech info area. One for a two-joint driveshaft, and one for double cardans (single joint at one end and a double joint at the other). I have assumed that the stock rzeppa driveshafts would use the two-joint chart, since that is the orientation of the pinion/tcase output from the factory. Is this incorrect?
