Rear passenger coil spring
Hello guys neww to the formJkur 14 , ls3 and alot of mods
SO since i had coil over i had the same issue that my car is lowered 2 inches on the rear passenger side, so i had to add 2 inches rubber . Even if my gas tank is empty , its the same thing . When it was a coil over. I was raisaing the rear right 2 inch more . The shock is also full open.
Maybe thats why i feel the steering darty and float on the highway . 2.50 inches rkLong arms teraflex .
Let me make sure that my understanding of what I read above is correct: When the Jeep is leveled (by the rubber spacer you inserted), the shock on the passenger rear is fully extended, but the shock on the driver rear is not? That doesn't sound right at all. I mean, something is seriously amiss. Bent or wrong part maybe? I have no idea. As for the flighty steering (which you may have correctly said is due to this other problem): Who did the alignment and what specs did they use? If they used factory specs for that lift, you might discuss with them adjusting the caster a bit to improve the steering feel. This is a common issue with lifted Jeeps adjusted for OEM front caster specs.
Extended shock
