Rear license plate relocation help
Old 10-14-2015 | 01:03 PM
Ripa777's Avatar
Default Rear license plate relocation help
I just received my swing away spare tire carrier and need help on rear plate location. I have OR - FAB and the spare mounts thru the center of the spare. Anyone have suggestions. Don't want factory location. Thx. For help
Old 10-14-2015 | 02:13 PM
Wildschwein's Avatar
I'm considering a plate relocation as well and thought I'd go ahead and get linked up to this thread.
Old 10-14-2015 | 03:51 PM
afpilot82's Avatar
Veteran: Air ForceJK-Forum Ambassador
How about Or-Fabs license plate mount?
http://www.orfab.com/details.php?App...KET&Active=Yes
I used that along with the ORO license plate/3rd brake light and it works perfect.
http://www.extremeterrain.com/off-ro...D&XTID=J100400
Old 10-15-2015 | 11:26 AM
Ripa777's Avatar
How about Or-Fabs license plate mount? http://www.orfab.com/details.php?App...KET&Active=Yes I used that along with the ORO license plate/3rd brake light and it works perfect. http://www.extremeterrain.com/off-ro...D&XTID=J100400
Haaaaaa. Thx! Duhhhh!!! I Actually looked at that item before posting .... Misread the TBar mount part in the item description. Thx again.
Old 10-15-2015 | 02:22 PM
Cuv's Avatar
Cuv
I used to have that carrier and mounted mine to the T bar. I drilled two holes in the bar, put a bolt in facing rearward with a flanged nut on backwards so the license plate had a flat place to sit, and used wing nuts to hold the plate. Wing nuts were in case I had to use the spare, ease of use. I wired a light to it but I can't remember what brand, and used a quick disconnect for the wires . Worked great and not bulky! And easy to remove if you need the spare.
Old 10-15-2015 | 02:42 PM
Ripa777's Avatar
Used to have? Insight pls before I drill and mount to my jk. Good carrier?? Y did u get rid of it?? Thx
Quick Reply: Rear license plate relocation help
