Rear JKS Trackbar rubbing on Tereflex Coil
Old 02-06-2010, 06:43 AM
MoridinTX's Avatar
Default Rear JKS Trackbar rubbing on Tereflex Coil
I installed my TF 2.5" coil lift two weeks ago and just re-torqued all the bolts. In the process I noticed that my new adj. JKS rear trackbar is barely rubbing the right rear TF coil spring. Specifically it is the nut on the trackbar that is rubbing the coil.
Sorry for the large pictures, how do y'all do the little thumbnails that link to the large pictures
Picture 1 where the nut is rubbing the coil.
Looking straight up, I have about 1/4" clearance between the trackbar and the coil. I tried to highlight the edge of the coil, but my photoshop skills are non-existent.
Do yall think this will be a problem long term, and what should I do about it?
Old 02-06-2010, 06:48 AM
mkjeep's Avatar
Get the Rockrawler spring wedges, you put them between the coil and lower mount and it'll straighten your spring.http://www.rockkrawler.com/pages/cat...p?r_itemID=247
Old 02-06-2010, 06:55 AM
MoridinTX's Avatar
Thanks for that info! When you use these, do I replace the factory spring isolators with these, or add these to the existing isolators?
Old 02-06-2010, 07:05 AM
mkjeep's Avatar
Those go on the bottom of the spring, not the top, your factory iso is on top. These go on the axle pad.
Old 02-06-2010, 07:06 AM
MoridinTX's Avatar
Excellent, thanks for the info
Old 02-06-2010, 07:08 PM
sktdarkstar8's Avatar
u dont happen to have adj. rear controls arms? i had the same problem with my 2.5 and my jks trac bar and it was becaz my axle was pushed to far back even with my control arms adjusted all the way in.
Old 02-06-2010, 08:38 PM
ElovesC's Avatar
I went with the JKS spring re locators they work really well and they allow for precise adjustability.
Old 02-06-2010, 09:23 PM
spinlock's Avatar
Pics and text removed ...
In general, any type of suspension interference issue is going to be a problem in the short or long term. What may appear to be barely rubbing in a static position can be a major inteference problem when the suspension flexes.
I think you've gotten a couple of good solutions to your problem.
Old 02-07-2010, 05:06 AM
MoridinTX's Avatar
Alas, I did not get the adj. control arms for front or rear. I did not think they were necessary.
Thanks for the information on those. I was not aware JKS sold those either.
Thanks for all the suggestions everone
Old 02-07-2010, 05:50 AM
Ryanc's Avatar
I use the Teraflex rear axle bracket and the stock track bar, no rubbing. I had rubbing with the JKS rear track bar.
Quick Reply: Rear JKS Trackbar rubbing on Tereflex Coil
