Rear end squeaks only when i have a passenger
Originally Posted by Rich6700
Have someone sit in the passenger seat and someone bounce the truck while you look and see where the squeak is coming from.
That with the title... LOL Only thing I can say is if the rear end is squeaking when some one is riding in the back, get some lube it will quiet her down!
On a serious note best of luck on getting the issue fixed. These things will drive you crazy.
Ok. So I am ordering some skyjacker track bar brackets for 2-4" lift. Would that help with the noise? Possibly fix it? I was going to put these at the rear and the stock rear at the front
Skip brackets all together and just pick up adjustables front and rear, they will last you longer and will allow the perfect alignment of your axles., not matter what lift you stay with.
But honestly I wouldn't be buying anything until you can actually diagnose where the sound is coming from.
Adjustable front and rear track bars? And when I drove home tonight it made the noise without a passenger today. And it sounds like the coil is being hit
