Rear Drive shaft died Need help
I have a 09 X 2dr with a 3" teraflex lift and my Rear Driveshaft went at the transfer case. Please tell me what I need to fix it.I really dont want it to break again because it is my daily driver and my only vehicle. I know i need a driveshaft but which one and how do I go about ordering one. Also Can I just buy rear adjustable control arms do adjust rear axle. Im still very new to this.Thank for any help.
I checked your profile, 2-dr , right? They do make OEM replacement driveshafts that bolt up to your flanges. Or you could change the yolks out. Either way , you'll need to get adj uppers in the rear to adj the pinion angle.
Here is a write-up for the rear shaft.
https://www.jk-forum.com/forums/jk-write-ups-39/installing-je-reel-1350-rear-driveshaft-28160/
