Rear brake rotor ticking.
Ok so i bought a new set of front and rear drilled and slotted rotors for my 2014 JKU. Install was smooth everything fit perfectly. I've done several hundred brake jobs so it's not from lack of experience. During the initial test drive/break in i noticed an odd ticking sound. After much trial and error it ended up being the rear rotors. So with the new pads installed and using my stock rear rotors, there was no ticking noise. I contacted the vendor and they sent me a new set of rear rotors. So i installed the second set of new drilled and slotted rotors and went to do the test drive/ break in and wouldn't ya know it, it started ticking again. The ticking sound is constant. It's not only when i hit the brakes. It's easier to hear at slower speeds but i can hear it as i slow down from higher speeds, even without touching the brake pedal. It sounds as if the ticking sound speeds up when i do apply the brakes. There is no issue with brake function at all. They stop great. Anyone have any thoughts on this?
There's some flat-spring clips that hold the pad tight in the caliper. Did those get replaced? When they don't, a problem can be a metallic click when the brakes are initially applied. A dab of brake grease helps as well. This isn't the exact symptom you described, but I'm wondering if the slotting is somehow causing the pad to move enough to make a click. Another thought is that the rotors have too much face runout, which makes the pad move back and forth each revolution.
I had the same thing with the slotted brakes on my Pontiac G8. Almost sounded like a card in bicycle spokes. I just got over it. I don't notice it at all with the slotted rotors on my 1-ton axles on the Jeep though.
