Rear Axle Retaining Nuts
Old 10-31-2015 | 07:43 AM
kjeeper10's Avatar
Vet Army
Originally Posted by bruckus
kjeeper, if you are going to do your own axle shaft install - jack the rear end, remove wheels and try to loosen the 4 nuts on each side first... if they start spinning (the head of the bolt will sometimes spin in the retainer plate itself), then you will know you have an issue + know you will need to cut off any spinners/get replacement nuts for those. My new axles/retainer plates did not come with new nuts.. To answer my own question above re: using lock washers, did some reading and found that the Mopar nuts are torque nuts (they crush/deform to hold their tension) - which would be important given the vibrations and potential to loosening. With that said, the lock washers (split washers) I have used are not ideal, and would be considered second best to chemical locking compound (loc tite). I am going to keep the 6 new coffee can nuts used, and add loc-tite today. Will mark them with a paint pen and re-visit this at next oil change for any changes. For anyone installing rear axle shafts, you may wish to tack weld the 4 retainer bolts to the retainer plate prior to install (to prevent them from spinning down the road). I am hoping these G2 axles never need to come out and have fingers crossed they won't spin if I try to remove them.
Thanks saved !!!
Quick Reply: Rear Axle Retaining Nuts
