Rear Axle moved after 2.5 BB TeraFlex
Hi!
I bought it new. It should also be a new kit because the rear bump brackets are shaped as a parallelogram. I bought it through oconeeoffroad.com for 233 bucks.
Thanks,
Alex
Thanks,
Alex
Graf,
If you're still lookin for a rear bracket, I just put one in the ads. Your post reminded I had one sitting in the garage.
sale ad link > https://www.jk-forum.com/forums/show...323#post692323
Good luck with your hunt(s).
RB
you'll forgive me but the 4" lift in question does not come with adjustable control arms, front track bar drop bracket or dropped pitman arm. for 4" of lift, these would be things that i would require. also, i question their use of a rear track bar relocation bracket that attaches to the axle and while they do work - sort of, i question the use of cam bolts to set your caster. but hey, that's just me.
back on topic, for the price (about half the cost of the above mentioned lift), you can have one of the most complete budget boost on the market today. and in my opinion, that is a bargain.
good in the front end,and also with that adjustable front track bar as you add weight to the front end ie steel bumper,winch,rack,pree runner bar ect you can adjust it to keep the axle centered
You dont need a front track bar bracket becouse Superlift comes with an adjustable front trackbar ,and keeps it in line with the steering drag link bar witch eliminates the need for a drop pitmin arm. With these track bar , and steering draglink bars at the same angle it eliminates bump steer keeping the geometry
Sponsoring Manufacturer
