Rear axle articulation limited, need help
Old 06-22-2009 | 03:15 PM
bigbluejk's Avatar
Default Rear axle articulation limited, need help
I was wheeling this weekend and noticed that my rear tires were not stuffing up into my wells like I expected them to. So I drove up an RTI ramp backwards to see what was going on... I looked under the Jeep to see why my tire wasnt stuffing before the body teetered and I saw that my axle was like 2" form hitting my bumpstop. I know that my shock isn't keeping it from traveling further up, and my bumpstop isn't keeping it from going up... what is?
Look at my axle, it is not that far from parallel to the jeep. It should be squished up at more of an angle than that. Any ideas are welcome.
EDIT: I should have said that I do not think anything is wrong with my lift, or jeep. I am happy with my lift and it works well, I am just trying to get more from it. That is why we mod to begin with, right? My theory is that my jeep is too light for the rear springs to compress without the jeep coming off the ground. I just want to make sure that there is nothing else going on that I am missing. Sorry, I worded this the way I did to spark fresh ideas without hearing my theory. Looking back, it looks like I think something isn't working right.
Old 06-22-2009 | 03:25 PM
RedneckJeep's Avatar
How do you know it's not the shock? Did you disconnect it?
Old 06-22-2009 | 03:32 PM
bigbluejk's Avatar
I did not disconnect it, but the shock was not fully compressed is what I meant.
Old 06-22-2009 | 03:39 PM
bigbluejk's Avatar
here is a better photo. See, my rear tire isn't really going into the well at all.
Old 06-22-2009 | 03:42 PM
NH4X4's Avatar
check to see if the inside of the tire is hitting the wheel well? You might need spacers
Old 06-22-2009 | 03:44 PM
bigbluejk's Avatar
I looked everywhere to find something hitting... I couldn't find anything.
Old 06-22-2009 | 04:01 PM
NH4X4's Avatar
maybee put the drivers side on the ramp and see if it does the same thing. check the sway bar and links?
Old 06-22-2009 | 04:06 PM
bigbluejk's Avatar
Both sides did the same... what you mean on the swaybar links? I was afraid that they might bend under full articulation cause I had them installed on the insides, and thought the links might hit on the axle, but I recently swapped them to the outside of the swaybar like they belong. I dunno if the axle had such limited uptravel before I swapped them around. Thanks for the ideas.
Old 06-22-2009 | 04:38 PM
bigbluejk's Avatar
I think maybe my jeep is too light for my spring rate or something. The rear tires squish up into the fender wells when the weight of the jeep is on them. see:
You can see that the tires don't hit anything on the way up, but the whole jeep goes in the air before the tire hits the bumpstop if the jeep is level and not tilted back like in that photo.
Old 06-22-2009 | 04:49 PM
NH4X4's Avatar
what lift do you have? did you change the bump stops?
hmm
Quick Reply: Rear axle articulation limited, need help
