Really Really super super embarrassing Tire Question
#22
12-14 mpg pre gears with O/D off.
#23
Originally Posted by Benchmark Designs Inc.
Exactly! I've seen 37s measure anywhere from 35" to 37.5". You can't go by what the sidewall says.
Based on what the OP is saying, I would look for something that measures out around a 35" tire. Check some 35s, maybe a 315/70R17.
#24
See I have a 6 speed w the mountain edition gears, I'm trying to figure out the weight diff between a 35 inch nitto trail grappler and the 33 inch open country hoping since the toyo is such a heavy tire the weight increase won't be too too bad, I read a gear change in a standard doesn't effect mileage much so it may not be worth it, insight?
#25
Type______________Size_____________Weight___Load Range__Price(each)
Irok Radial_________37x12.5 R17_________81_______E_________400
Interco SSR________37x12.5 R17_________90_______D_________385
BF Krawler_________37x12.5 R17_________87_______C_________485
BF Mud KM2________37x12.5 R17_________72_______D_________390
MTR Kevlar_________37x12.5 R17________74________D________385
Toyo Open Country__37x13.5 R17________93________E_________420
Nitto Mud Grappler___37x13.5 R17________90________E_________420
ProComp Xterrain____37x12.5 R17________83_______D_________380
ProComp Xtreme Mud_37x12.5 R17________83_______D_________390
Mickey MTZ_________37x12.5 R17________83_______D_________435
I was not sure about the KM2, some sites say 71 to 73 lbs
Toyos and Mud grappler are the heaviest, since they are 13.5 wide
#29
Originally Posted by jenly8
I run the Toyo 35 m/t with 5.13 gears and I get 12-13mpg. I think the rotating mass of these heavy tires is killer
#30
i found somewhere saying that the 35" Trail Grappler was 79 lbs and the Toyo open country 33.5" was 86 lbs...i would think at a 7 lb difference per tire, I shouldn't see much of any of a diff in mileage changing to the 35?
