Really bouncy ride
Really bouncy ride
My axle is off-centered about 2 inches to the left while looking at the jeep. This is causing my coils to have a bow in them and also the bump stops to be touching the side of the coils. I already have an adjustable track bar on the way to re-center the axle. So my question is that is it because my coils have a bow and are not straight the reason my ride is bouncy? and I mean REALLY bouncy. Thanks!
Also, when the lift was installed, were the trackbars and control arms all loosened while lifted, and then not tightened and torqued until full weight was on the ground?
Yes I meant passengers side is probably bad. I'll unbolt it shortly and check the pressure. And It has been lifted for awhile now, I just never got around to buying a track bar to align my axle because the ride was fine! Just in the past few days has it gotten bouncy and I was trying to figure out why. My guess is the shock though
Also, the comment about tightening the assembly with the Jeep on the ground is important. When the bolts are tightened with the Jeep on jack stands it puts unwanted pre-load on the components and weird things will happen with the ride and handling.
