Ready to start my build... But questions
I have a 2011 jku sport. Wanting to go Teraflex 2.5 with 35's and rear bumper with carrier. Soon after I will replace the front bumper and add a winch. I don't want to put the front bumper on and go "shit! Now the front is two low"! What is the best option without needing to swap out drive shafts and other equipment. I've researched a TON! But still can't decide. And I absolutely want it to be leveled out. Thanks in advance!
![FJOTM Winner](https://i.ibb.co/FgFLpFN/Untitled-1.jpg)
Unfortunately, the best option is to wait until the coils are in and all the weight is bolted on. That way you can determine what size spacers to add to get you back to the height you want. Otherwise, you are just guessing. Or going by what worked for someone else - which may not work the same way for you...
For the driveshafts, there is more than just lift height to consider. It could also just come down to plain ole luck, as there have been posts from people with 2.5" lifts who needed to replace them.
I did however tear the boot on my front driveshaft.........tore it once I disconnected and took it offroad
I would add the weight, and then do the lift, if possible, or else you will end up having to readjust multiple times with different spacers as you add weight.
Jeremi, don't worry about sagging. I've had the Teraflex 2.5" coil lift for years. No sag, and plenty of extra weight on my JK. Great set-up, enjoy it.
Thanks again everyone. My brother has a teraflex leveling kit. He was wondering if he swaps to a 2.5 coil lift like me if the 1" rear spacer from the leveling kit could be used in the front of mine if needed with a heavy bumper?
