Re-Using Diff Oil after a Cover Change?
Hey Folks,
I just got a set of front and read Riddler diff covers for my JK. My question is this: After installing the new covers, can I re-use my differential gear oil? I just had it changed a couple of months ago, and don't really want to spend another $60 on top of the cost of the covers. So would it be okay to capture the diff oil and re-use it, keeping track of which diff they came from?
My only concern is that the Riddler's may need more oil than the stock covers. Could I then add oil to top off the old stuff, or should I just bite the bullet and put all new oil in them?
Thanks for the help.
P.S. Pics of the painted Riddlers to come on Tuesday...
Sponsoring Vendor
Alpha Expedition
Alpha Expedition
I have always used new oil each time I pull the cover(s).
But I do know others who have reused their recent filled oil back in as well. Just be sure it is clean enough!
Theres no problem with it, in my opinion, as long as the fluid is in good condition still. But if you drain it and it looks like used then you might as well change it. I don't think theres a problem with mixing old and new either, as long as its the same stuff. My dealer has recaptured my mobile 1 and reused it several times (I had some issues with my lockers which required several trips and several inspections/work/etc) I change my diff fluid a lot more than is recommended, as with all my fluids, but I'm weird like that -- but I still don't see a problem with reusing good fluid.
I would reuse it. Before you fill it up, run a magnet through the oil when it's in a pan and use a strainer to get any flakes out. Make sure you top off in case the new covers hold more oil.
