re-gear question..
Old 08-18-2016 | 06:22 PM
Housegoat's Avatar
Default re-gear question..
Getting ready to order gears and install kits, in the past with other vehicles changing from a 3 series to a 4 series gear required a change in the carrier?
Is that true for the JK's as well? Im not changing lockers or anything, just wanting to go from 3.73's to 4.88's for the tire change..
Old 08-18-2016 | 06:30 PM
TxRdStr's Avatar
If you have 3:73 your good. Carrier is useable.
Old 08-18-2016 | 06:41 PM
casamtb's Avatar
Do you need anew carrier with 3.21 to 4.10? I am just starting to look into this.
Old 08-18-2016 | 06:49 PM
Housegoat's Avatar
Old 08-19-2016 | 05:23 AM
(none)'s Avatar
yes you do.
Old 08-21-2016 | 12:16 AM
casamtb's Avatar
Thanks.
Old 08-21-2016 | 05:06 AM
lowendrider's Avatar
Default Locker time
Another thing to think about...if you want a locker or limited slip, may as well do that at the same time if you're going to have to go with a new carrier anyway. You'll save $$ in the long run if you think you'll need or want some type of traction aid.
Old 08-21-2016 | 05:07 AM
Default front only
front carrier only when moving from 3.21s....you'll be good in the rear.
Quick Reply: re-gear question..
