Re-gear/LSD & Lockers, everyone's favorite topics
I have a JKU Sahara and use it as my daily driver, with some fun off road.
I plan on making the journey out to Rausch Park on occasion, and eventually Moab, but mostly will use it on the weekends on the beach in Island Beach State Park.
I notice that the esp system drags down on the jeeps forward momentum, seems very apparent to me in the snow and on the sand - am I right?
So.... I am anxious to either put in a locker or lsd in my jeep.
The story continues.....
I currently have a TF leveling kit and am hoping my stock tires wear out quickly. Once they do, I am planning on going with 33 inch tires, most likely Duratracs, but who knows. Please note, I have an automatic tranny with 3.73 gears.
So I don't want to go about my mods in a stupid way, that ends up costing me too much $$$.
Here are my questions -
If I only want to run 33's can I get away with a Superchip's Flashpaq instead of re-gearing?
I was thinking of putting a LSD (Truetrac) in the front (Dana 30), and a selectable locker in the rear at a later date (would get before I ever go to Moab). Is this a dumb move?
So here is the order I was thinking: 1. LSD in front 2. 33's 3. Flashpaq 4. Rear Locker
I hope I am making sense here, and not just rambling.
If you have the cash laying around, it's hard to beat ARB's front and back - but it doesn't really sound like you need them. Get TrueTracs front and back and call it a day.
For the order:
1. Flashpaq
2. Tires
3. Gears/Traction Devices/Gussets/Sleeves
Don't forget to strengthen that D30 if you are planning on Rausch and Moab
For the order:
1. Flashpaq
2. Tires
If I put a LSD in the front now and decide to regear and put in a locker in the back later, am I going to be eating a lot of labor costs?
Does it cost a lot to put a lsd in the front?
When you re-gear, they have to pull the axles apart.
When you add lockers, they have to pull the axles apart.
When you add sleeves, they have to pull the axles apart.
So yes, if you add a front locker/LSD, you will be paying labor a second time to re-gear. And a third time to add the sleeves. And a fourth time when you figure out that you didn't gear low enough. And...
For the costs, labor charges will vary quite a bit, and will depend a lot on how much experience your shop has. Some will take a lot longer than others. And the last I looked, a D30 TrueTrac was $390ish. The ARB is $850ish, and will need a compressor/panel/switches/bracket/etc also.
