re-balance Front shaft ?
My current front 1310 driveshaft had a flange yoke on the pinion. My new 44 has a standard 1310 pinion yoke. I took off the flange yoke and simply put the u-joint into the pinion yoke and installed the u-bolt kit. Length seems correct.
Will I need to re-balance the shaft because of this ?
