RC stinger on a stock bumper?
Old 10-04-2011, 06:00 PM
09jaykay's Avatar
Default RC stinger on a stock bumper?
I was wondering it this stinger could be mounted on a stock bumper, looks like the mounting holes would line up with the four bolts that hold on the stock tow hooks. i know there would have to be some cutting done to the plastic cover to make it work, Any insight would help thanks
Old 10-04-2011, 06:49 PM
o09jkny's Avatar
With a little drilling, cutting, and heavy duty bolts, I don't see why not.. Depending on how wide those mounts are apart, the stock bumper may need to be cut on the front where the bumps are.. I also foresee the tow hooks having to come off.. Whatever the case you need to mount it in such a way that it is sturdy enough to pull the whole rig by it.. Remember: If there's a will, there's a way!! Please do a write-up if you decide to do this.. Should be interesting!!
Old 10-04-2011, 06:52 PM
knnphillips's Avatar
Sure it would work you will have to remove the bumper and take crush cans off. Then slot the plastic from the stock tow hooks back so that you can slip the plastic back over the metal subframe and stinger.
Old 10-04-2011, 06:57 PM
09jaykay's Avatar
I think this and the VDP end caps would make a nice $200 stubby bumper, mite have to try it!!
Old 10-04-2011, 07:37 PM
Wandell's Avatar
I'd love to see this!
Old 10-06-2011, 03:54 AM
Wandell's Avatar
Also, is that the Rugged Ridge stinger for their bumper?
Old 10-06-2011, 09:26 AM
09jaykay's Avatar
This is a rough country stinger for their stubby bumper.
Old 10-06-2011, 11:07 AM
TCORUM's Avatar
rc stinger does not have the same bolt hole pattern as the JK frame horn plate.
Old 10-06-2011, 12:02 PM
D_engel's Avatar
RR stinger will bolt up with a little drilling.
Old 10-07-2011, 03:45 AM
Wandell's Avatar
Has anyone done this? If you have, post a pic.
Quick Reply: RC stinger on a stock bumper?
