Rc 3.5
#21
but the main reason to use the adj trackbar is so that theres not additional stress on the sector shaft/steering pump which is caused by using a drop pitman arm
#22
When i installed my kit i couldnt get the pitman arm off so i had alot of bump steer, Not sure if that would still happen if using the drop pitman arm.
#23
From what i've read, The drop pitman arm/trackbar bracket is used in place of an adj trackbar to lower the price of the kit. i cant really see any advantage using those over an adj trackbar other than bring the cost down
