RC 2.5" Coil LIft or Rustys 2" Basic Lift
Im also considering these two kits. Also considering the Teraflex 2.5" coil lift. My only concern with the RC & Rustys is not having the swaybar links and trackbar (bracket) & brake line extensions, etc. included in the Teraflex kit. Only problem is that the TF kit is almost twice as must as Rustys or RC.
im looking at the same 2 kits, 2.5" terraflex or the 2.5" RC. and have noticed the RC doesnt come with the end links or track bar brackets.
So my question is to all the guys running the RC 2.5" how is it without these parts? would the alignment/caster be way off? and the driveshafts not be centered? or because its only a 2.5" lift u dont really need these options?
I dont mind holding off and getting the terraflex as i know its more expensive but it is complete, just wondering if the parts included in the terraflex are necessary with only 2.5" of lift, because the RC, OME , RUSTYS 2-2.5" dont come with these parts.
thanks for the help!
I know a few people with the 2.5" RC lift and they didn't need anything extra. Now i'm not sure how hardcore they are so they may or may not notice issues, but they've had nothing but good things to say.
RC did have some issues at the beginning with their JK lifts.. but every day they pick up more and more.. new shocks to replace the old ones that leaked alot.. and instructions with a TAD bit more detail lol
It comes down to your personal tolerance for non-stock handling and looks. Would you be better off with a more complete kit that addresses more of the issues involved with lifting? Of course. Can you get by with a less expensive lift? Yes --> and then add more components as you go...
At 2.5":
your caster will be low, causing some flightyness. Can you live with it? Lots of people do. If it bugs you, grab a set of front adjustable ca's
both axles will be shifted to the sides. With stock tires, you may not even notice it. With larger tires, it will be very noticeable that one side is sticking out. As long as it is not causing issues with the computer controlled steering/braking systems, you can live with it until you get around to adding brackets or adjustable trackbars
the swaybars will be angled down. On streets and fire roads, this should not be an issue. You will want to be very careful if you go offroad and flex. Short links can cause the swaybar to flip around backwards, which will do some damage. (same with being on a lift at the shop!) As long as you are aware of the issues, you can add these later.
Just get a grasp of what each of the components does, and decide for yourself what 'you' want/need...
At 2.5":
At 2.5":
At 2.5":
