rattling from rear brakes over bumps
Anyone have a rattle when going over small bumps coming from rear?
I originally suspected CA bolts or shock mounts but all were tight.
Then I tapped the rear calipers and they click/rattle.
Verified by going over the bumps while applying brakes and it doesn't make the noise then.
here's that post as relating to our issue and at first we thought it was an electrical issue.. But often one could dico the battery and clean the terminals.. Brake The Electrical Issue
We had this same issue which lead to the rear brakes locking up.. the left rear pad was left looking like a leaf while the rotor was pitted and eaten up as well.. I would have someone remove the rotors and check the emergency brake and if there is any sort of build up inside the rotor (as our did) the e-brake would constantly make contact and simply wear out.
I just never thought the bracket and guide pins were a wear item
Sent from my LG-LS980 using JK-Forum
Update...
Pulled the calipers apart and filled the slide pin holes with caliper grease and cleaned up the anti rattle clips and noises are gone.
Thanks for that great advice
gordysmithtwo@gmail.com (05-04-2021)
Good to hear.. and you're prob tired of hearing me say unplug this, unplug that.. but everything is electrical these days.. wasn't like this back in the late 70's.. miss those years..
Not like my old Dodge Ram Prospector. Those were the days....
