Raptor style grille lights
#61
Thats what I did with mine. Used a quick connect from radio shack and spliced them into the passenger side turn signal. That way if I have to take the grill off, just quickly unplug them. And it also makes it look factory. The LEDs draw such little amperage that you won't blow a fuse. I have 14 superflux LEDs wired into the interior dome light loom and have never had a problem.
#62
#63
#64
I used a 12v tester to determine which wire did what. You'll have 3 wires, ground, white, and white with a tracer. I can't remember which white wire is the running lights, but if you just turn on your parking lights, hit the wires with a tester, then turn on the blinkers and check them again. Good luck!
#65
Anyone do up a light colored Jeep? - the dark colors look good, wonder how well they show up on other, lighter colors.
#66
I'm writing a thread on it now.. I can't get the photos to load though... I don't want to jack anyones thread.
But for now, here are some good threads I used
https://www.jk-forum.com/forums/jk-e...hts-~~~-94632/
https://www.jk-forum.com/forums/jk-e...ighting-61034/
#67
Roger on not wanting to jack someone else's thread. PM me if/when you do your write up. I'd like to see what you've done. (I haven't tried attaching any photos to a thread yet, so I'm no help there).
cheers!
