Rancho Shock damaged
hi all
please help
![](http://my.project-jk.com/data/500/medium/shock.jpg)
This is what happened to the rear (right side) shock. as you can see from the picture the track bar bracket is too close to the shock, did this happen to ony one else or just me.
also noticed that the rear sway bar link is already in contact with the axle mounted bracket.
![](http://my.project-jk.com/data/500/medium/shock-1.jpg)
Is there any way to avoid this happening again?
please help
![Talking](https://www.jk-forum.com/forums/images/icons/icon10.gif)
Throw the rear sway bar link in the garbage.
![Big Grin](https://www.jk-forum.com/forums/images/smilies/biggrin.png)
Looks like the shock gets under that nut there under compression, and the dent is down low at rid height, etc.....so maybe space the lower shock mount out a bit to clear under compression, etc....
Do you think if i removed the track bar bracket and just install an adj track bar might help with this?
I just installed some rancho shocks yesterday, and I already have the dent. My first set of shocks had the dent too, but the last set didn't. The difference seems to be the diameter of the shock itself. Short of getting rid the track bar, I dont know what to do about it.
Here are a couple thoughts for you, in regards to relocated the track bar why not just relocate the shock mount?
You also might consider turning your shock upside down so the shaft is at the bottom. Then it would only hit the boot?
With the heavy end of the shock attacked to the body you lessen any bounce and axle/wheel/tire weight reaction to springs and shocks slightly more acceptable.
What brand of good shocks that come with the shaft at the bottom?
I have ordered a new track bar already
, hope this will assist solving the problem.
What can be done about the sway bar links? i need to get this done right once and for all as i dont like keep changing or worrying about shafts when i am on trail.
![Yup](https://www.jk-forum.com/forums/images/smilies/yup.gif)
Getting a monotube shock that can run can up, etc...as mentiioned could help....as would moving the lower shock mount, etc. The adj track bars might mount to the same point, so I'm not sure it that's a realistic fix, unless you need one to re-center the axle anyway.
I'm also partial to the Bilsteins, they are fantastic shocks.
