Rancho 4-inch sport lift driveshaft questions.
If you aren't going to disconnect the front sway bar and go rock crawling or climb through trenches, you don't have anything to worry about w/ the front drive shaft. The whole problem with the front ds is that the longer shocks + a disconnected swaybar = more droop than factory specs were made for so the driveshaft contacts the transmission skid and tears the boot that seals the two sections of the driveshaft. So as long as the curbs she'll be crawling at the mall aren't too big I think you'll be alright.
Again, it is not a Rancho-specific problem, it will happen under those conditions with any 4"+ lift.
I have a 2012 JKUR with the Rancho 4" Sport Lift and Zone exhaust spacers. Still running stock driveshaft. Granted my Jeep is only a couple of months old and only off-road 1x so far, but I did flex it out and there were no markings or interference with the driveshaft and the exhaust.
So if this is your wive's Jeep and not expected to go off-roading, then you will be fine. Otherwise get the exhaust spacer for cheap to gain a bit of clearance. Driveshaft will be fine.
If in the future you start doing more off-road and flexing and then the driveshaft starts to fail, replace it then.
Otherwise save the money and do another mod.
This right here, if you find yourself pushing the JK down the road keep an eye on it.
my 4" sport lift did not come with longer brake lines, but did come with drop brackets for them and i've never needed anything more. They do get really tight at full droop when the sway bar is discoed and i'm on the rocks, but that probably isn't going to be an issue for you. Not to mention, your 2011 has longer brake lines to start out with in the front if you just free them up.
You probably wont NEED an adjustable trackbar, but that is something that i would recommend. The track bar takes a lot of force and a drop bracket multiplies it by adding leverage against the track bar mount. If you're going to off-road it any, i would definitely upgrade the trackbar. Even for mall crawling, an adjustable track bar would still be a good idea because if the track bar bracket works itself loose it could cause the dreaded death wobble (took me weeks to remove the stain on my seat cover after I got it for the first time). Not to mention the pitman arm would have to be swapped if you use the trackbar drop bracket to maintain proper steering geometry, which is a real pain in the ass and requires a pitman arm puller... It also puts more strain on the steering box by adding leverage.
So the new 4 inch rancho sport kit I bought has the longer brake lines and an adjustable trackbar. Also you dont need to change the dreaded pitman arm, it maintains the stock one.
