Rancho 2" Sport Suspension System on a JKU
#41
I read they do this to take into account aftermarket bumper and winch. I can see it being level after adding some weight to the front. I will say this lift is an awesome deal for $275 after the rebate!
#42
Sent from my iPad using Tapatalk HD
#43
Nope, this is the opposite. JKU is heavier and the kit uses the same front coil spring, so it produces more front lift on a JK requiring the taller, 1.75", rear spacer to level out the JK. I have two of these kits - one on my JKU and be on my wife's JK. Both are level and we used a .75" rear spacer on the JKU and 1.75" on the JK.
Andrew
#45
So I attached my trailer today, and with the hard top on there was definitely some backwards rake going on, and i only have a single place stand up jet ski trailer, its not even that heavy.
If I were to replace the .75" space with a 1.75" spacer, what else if anything would/should I fix on the rear end?
I'm assuming some new links for a start, but not sure if anything else.
#46
I did a lot of reading before deciding on this lift for my 2012 JKUS and couldn't be happier. During the install we just cut off the front passenger shock instead of removing the fuse box or bleeding/cussing a lot. We also duplicated the rear brake line brackets and used them similiarly on the front with a gentle bend of the factory formed brake lines.
On road performace at the firmest shock setting is rougher than stock but I can also have a lot of fun taking interstate clover-leafs. Softest setting with deflated tires is definately trail ready. I can't wait to try my new quick disconnects with this lift; hopefully this weekend.
I can't say enough good things about this kit: form, function, instruction, price. I added the Rancho High Clearance Steering Stabilizer about a month after the lift. Great add-on/complement for this lift in my opinion.
All-in-all the best thing I've done to my jeep since removing the factory front air dam.
#48
I almost wish I would have ordered the 2 door kit. I know everyone's case is different so it's difficult to make a be all end all kit.
Even with a 1.75" rear spacer on the 4 door, there is less rake than factory, and i'd rather have a small amount of forward rake than any backwards rake.
#49
I agree that stiffening the shocks when towing is best practice, however, stiffer shocks don't magically make backwards rake go away.
#50
Was running a Teraflex 1.5" leveling kit (2" front spacers, 1" rear spacers). Front end was sagging so I pulled one 1" spacer from the front and swapped in the Rancho 2" springs. Front end is lower by .75" with no winch. I should've opted for 3" front springs since my winch is coming in next week and I'm gonna have to re-add the spacer to keep it closer to level.
