Rancho 2" Sport Suspension System on a JKU
Old 05-01-2013 | 09:05 PM
Namtaru's Avatar
As was said, my biggest issue was I didn't have tall enough jack stands. Luckily a fellow local jeeper swung by and helped me out.
I only had 2 ton stands, of which I have since bought new ones, 4 ton stands worked plenty fine.
For the top nut on the front passenger shock, mine was 5/8ths and I was able to get it off and back on without removing the fuse box, i just cut a little bit of the plastic away and it made it much easier to get at.
I had never installed coils before and got the whole thing done in about 4 hours, well 5, but the first hour I was just dicking around.
I found that having a second person around was VERY helpful.
Old 05-02-2013 | 03:39 AM
OH9JK's Avatar
JK-Forum Ambassador
Originally Posted by Rancho
As mentioned if you get this from Amazon, it will only fit a 4 door at this time, we are in the process of getting the 2 door part number added to their system it just takes a while.
What is different between the 2 dr and 4 dr kits? Is it just the springs?
Old 05-02-2013 | 05:54 AM
kjeeper10's Avatar
Vet Army
The rear spacers are taller on for the 2 door ... I think
Old 05-02-2013 | 07:32 AM
Rancho's Avatar
Sponsoring Manufacturer
Correct.
Old 05-02-2013 | 09:15 AM
OH9JK's Avatar
JK-Forum Ambassador
Taller rear spacers to compensate because the front springs are same on both kits?
Old 05-02-2013 | 09:52 AM
madmike232's Avatar
Yes it nets a bit more then 2 inches
Old 05-02-2013 | 10:00 AM
sgtkersh's Avatar
Yes, and I think the spacer difference is 1". 4door version is .75" rear spacer - 2 door is 1.75" I believe.
Old 05-02-2013 | 10:08 AM
nicksabellajk's Avatar
Did you need any other adjustment, when installing this kit, brake lines etc.?
Old 05-02-2013 | 10:12 AM
Rancho's Avatar
We do suggest an alignment. The kit comes with rear brake line drop brackets.
Old 05-02-2013 | 06:02 PM
sgtkersh's Avatar
On the alignment, my experience has been on both a 2DR and 4DR 2013 that we just needed to adjust the drag link to recenter the steering well. The rest appears fine.
Sent from my iPad using Tapatalk HD
Quick Reply: Rancho 2" Sport Suspension System on a JKU
