Ram Assist Steering
Old 10-24-2013, 03:30 PM
SF Nick's Avatar
Originally Posted by Red Dog
There prices are reasonable. Are you using one of their units?
Yes, I'm running the stage III complete kit, with the new pump & haven't had any problems. I did add a Cooler just to be sure it didn't over heat.
Old 10-24-2013, 03:37 PM
ChesterJFK's Avatar
If you use your stock pump could you add a larger pulley to get more volume?
Old 10-24-2013, 04:01 PM
JKphotoshoot's Avatar
Been running the redneck ram for awhile. Stock pump. Not twitchy at all. I trusted it enough to let my Wife drive my jeep 1700 miles from Mississippi to utah. Said it drove like a caddy.
If you try to go lock to lock real fast it has a slight lag. Otherwise its been great.
I made a custom bracket for my PR 44 that pushes towards the knuckle so it would quit bending tie rods in the middle.
Old 10-24-2013, 04:23 PM
Maertz's Avatar
i believe you would need a smaller pulley so it rotates faster..
Old 10-24-2013, 05:32 PM
big dr's Avatar
Originally Posted by Maertz
what size ram did you use? i am at about 200 ish in parts and will be doing my own on the stock box. I have heard on the 1.5" ram its not bad, but 1.75 it is.
Mine is a 1.5. It was good for everything,, except at slow speed when you needed to turn the wheel fast,,, it would bind up,, but you learn to drive in a manor that avoids the bind. It will work for you untill you can manage the pump,,, I ran with mine like that for almost a year. Good luck!!
Old 10-24-2013, 05:38 PM
JK Forum Regional Rep
familytime's Avatar
I rebuilt our steer gear with parts from Red Neck,drilled and tapped as well,used PSC ram and pump kit,works like a champ.The problem with the stock pump is at idle,or crawling it just does not have the volume needed to move the tires.Red Neck can tell you how to increase pressure on your stock pump or go with the pump kit from PSC,with this kit now at idle you can turn the tires with one hand also at high rpm it won't have cavitation,a big problem when trying to figure which pulley works
Old 10-25-2013, 01:36 PM
Red Dog's Avatar
After getting your inputs and reading a bit I know that I can get the steering box repaired and add two ports for the ram and later I will get the ram, Pump, Cooler and reservoir. I hate to give my wife sticker shock so I might get a couple of the parts at a time. Thanks for the input. I trust you guy more than an article that can be bias.
Old 10-25-2013, 04:14 PM
I have to say that WTO was great at helping me trouble shoot and answer questions while I was installing my setup. They took there time with me on the phone and helped figure stuff out.
Ended up I had a bad steering box and they had me another one shipped out in no time!
Old 10-27-2013, 10:12 PM
Red Dog's Avatar
It’s surprisingly nice when a company actually has that kind of commitment. Nice photo a few post back too.
Quick Reply: Ram Assist Steering
