Quiet my D-Rings please!
Old 01-16-2012, 11:58 PM
  #21
Hskr4x4's Avatar
Daystar makes a d-ring washer in multiple colors. I know 4wheelparts sells them. There isnt an actual pic of them, but I've heard they work like a charm. I'm gonna pick some up intowm this week since Daystar and 4wheelparts are both located here
They come in a set of 8
//www.4wheelparts.com/Winches-and-Winch-Accessories/Daystar-D-Ring-Isolator-by-Daystar.aspx?t_c=18&t_s=124&t_pt=9330&t_pl=100282
(Washer pic is of isolator)
Old 01-17-2012, 03:40 AM
  #22
11REDJK's Avatar
Thumbs up
I wrapped elecrical tape around the screw in bolt as others have said. Once in the mount you cant see it, and no clanking....
Old 01-17-2012, 04:31 AM
  #23
maine07jk's Avatar
I use the ball cock washers on my rear bumper, but I can't fit them on the front. I found a piece of rubber roofing material and made my own washers last night. I then wrapped the shaft in electrical tape for now. We will see how that works!!!
Old 01-17-2012, 05:28 PM
  #24
minime's Avatar
Shrink rap?
Old 01-18-2012, 05:32 PM
  #25
minime's Avatar
If that was my only problem in life. ( ball cock washers not fitting) I would be ok with that
Old 01-18-2012, 06:37 PM
  #26
hagausaf's Avatar
Originally Posted by bbolander
on my 2006 LJ i went to ace hardware and bought some rubber o-rings from the plumbing department that fit over the shaft, used one or two on each side to quiet them.
this. cost me like a few bucks for 2 packs of them in case the others fall or break off over time.
Old 01-18-2012, 06:38 PM
  #27
TXCheney's Avatar
Wow, I hope this works out for you. Out of context this had me ROFL. hope the mods don't think this is dirty.
Old 01-18-2012, 06:51 PM
  #28
fish's Avatar
Location: Apple Valley, California Good ole Mojave Desert.
nothing dirty about it
Old 01-19-2012, 02:51 PM
  #29
tankcj's Avatar
I used a dishwasher return/vent hose from Home Depot or Lowes (I can't remember ) that had the same ID as the D-ring pin OD and just cut it into small washers. It's nylon reinforced so it won't disintegrate over time and it's cheap! You can barely see them in the picture
Old 01-19-2012, 03:06 PM
  #30
Shadow's_Jeep's Avatar
Originally Posted by liveniceguy
I went to Lowe's and found some large rubber grommets in the specialty parts drawers in the screw isle. These grommets are the type that you would use after you drill a hole in metal to protect wires running thru the hole.
I found these when the standard d-ring isolators were on back order and did not want to hear them rattle on my new bumper.
Hope that helps.
X2: That's what I did.
Quick Reply: Quiet my D-Rings please!
