Quick gear question/rationale
The difference on the highway is less than 200 engine rpm. It will make virtually no difference in mpg or engine longevity.
However, 4.88s will be better off road, and the mpg should be better for in town mpg.
Unless your daily commute is long at 75-80 mph, 4.56s don't make any sense. (They cost more than 4.88s.)
Do you have a long daily commute at over 75 mph?
Does less than 200 extra rpm bother you?
I would definitely rely a good bit on those charts...i used the charts when i was in doubt and i chose the gears that were better for off-road vs highway and i'm pretty happy, although factor in the true size of the tire...my 37's are really 35" +/-
Back when i had to pick tires & gears there wasn't as much talk about true tire size as there is lately, otherwise i might have picked 4.88 vs 5.13
I love the 5.13 but they are a bit low, but they crawl nicely!
matthew
matthew
Forum Tech Advisor
Again, don't "fear the gear."
Less than 200 rpm higher with 4.88s at highway speeds on 34" actual size tires compared to 4.56s.
More power. Almost no difference in fuel economy. 4.88s are less expensive than 4.56s.
The only way 4.56s remotely make sense is for long, daily commutes at speeds over 75-80 mph.
