quick disco question
I used the 0-3" Terra disconnect on My OME lift, which is about the same height you say that yours is. The sway Bar sits perfectly level with that combo.
Once lifted you just don't want to be using shorter ones ie. like reusing the stock ones, way to much risk of potentially inverting your sway bar should you be connected and droop low enough to have it reverse once everything comes back down, or up so to speek...if you can picture that...not good. Going a little taller shouldn't bother much providing if your connected you don't smash anything when fully compressed.
Hope this helps.
