quick answers needed now!
i am trying to put my axle shaft back in but it just wont go. it slide in, then a bit more (through the inner seal i think) but then nothing. i can turn it a little to the righ and left but no more than that.
i have read and people seem to say it just slides in. i have been trying to just slide it in for 2.5 hours now and am lost for an explanation.
please help before the frustration leads me to dowse this motha in gasoline and burn it to the ground
front or rear? make sure the seal or race isnt mangled and walk away if your getting too frustrated. it'll go but the last thing you want to do is break something just trying to get it in there
i would normally just walk away but i have a carport and my nbrs are freaking out that this things is sitting there without wheels.
stock shaft right? otherwise i'd say make sure the aftermarket shaft is the same length and spline count as the oem shaft your replacing. You gotta kinda lift it in . The end your holding needs to be a bit lower than the side your pushing in...
