Questions about Rubicon axles
#71
All of the parts arrived today It is going to the shop next week to get installed. After looking at the wiring harness and factory switch I think I am going to set it up just like it would have come from the factory.
#72
#75
#76
Yes I have the axles installed. I had a local shop do the work and it came out great. I did not use the factory switches and only used the part of the wire harness that plugged into the axle. I have full control of the lockers. They are wired so that when power is applied the lockers lock and when they are actually locked it lights up the light on the switch. I used ARB locker switches. Turning off the switch removes power from the locker and unlocks the axle. Everything is working great and I am climbing rocks that I was not able to before I had the lockers
#77
Location: Apple Valley, California Good ole Mojave Desert.
so.........anybody else going to do a write-up on the axle swap and switch hook up with details and pics????? sure would be helpful.
#78
My shafts came in. Soon as I get some time, the axle will be in!!
I was planning on doing a write up for the wiring, the axle is'nt really need.
just look at WOL fulltraction write up.
#80
