Questions about OME 619's on my 2015 JKU! Help Please!!
Old 10-18-2015 | 05:18 PM
punisher0822's Avatar
Default Questions about OME 619's on my 2015 JKU! Help Please!!
Good Evening. I have a 2015 JKU that has had 2.5" coil spacers put on the front and rear. It sports a set of Toyo MT's 35x12.50R18's. When I put the ARB Deluxe front bumper on, it caused the front end to sag quite a bit. It now has a very noticeable rake to the front and I haven't even put a winch on it yet. My question is, I just ordered a set of OME 619's for the front and a 3/4" front spacer. Will the OME 619's and 3/4" front spacer up front be ok with the factory coil springs and 2.5" spacers in the rear? Thanks in advance for any input.
Old 10-18-2015 | 07:52 PM
rsmwrangler's Avatar
I'd guess your nose will point high, specially because on top of the spring you'll be adding a 3/4" thick spacer
Also the Jeep might ride funny because the 2619 coils pressure rates are a lot higher than stock, so you'll have a harsher ride in the front compared to what you'll have in the back.
This guy went too high on stock bumpers, but at least you have 35's so the look will be a lot better, though i think you'll want more supporting mods for 3" or more.
https://www.jk-forum.com/forums/modi...-5100s-220025/
Quick Reply: Questions about OME 619's on my 2015 JKU! Help Please!!
