question on winch and mounting
Old 09-11-2009 | 10:06 AM
sladekos's Avatar
Default question on winch and mounting
I have read through a lot of the posts on mounting a winch/plate to both standard and aftermarket bumpers... I keep wondering though, do I need to get a plate specific to the winch? or are they all pretty much standard to each other?
So... let's say I get the Mile Marker PE8000 winch from Costco online (which does not mention any sort of mounting plate). Will I have to go searching for a Mile Marker mounting plate?
Old 09-11-2009 | 10:32 AM
gpb's Avatar
gpb
I can't speak to Mile Marker specifically, but *most* winches seem to adhere to a fairly generic bolt spacing. My Rugged Ridge XHD bumper install instructions only called out the Warn Powerplant as needing to use the alternate set of predrilled holes.
Old 09-11-2009 | 12:56 PM
yomondo's Avatar
It looks like the Mile Marker PE8000 has a 10"x4.5" bolt pattern, which seems to be pretty common. Warn winches use that bolt pattern. I think the Powerplant, because of its size it has to be mounted offset on the Rugged Ridge bumper, explaining the need for the alternate set of predrilled holes.
Old 09-11-2009 | 03:40 PM
hayden911's Avatar
Default Rough Country Plate...
I got the rough country plate for my Mile Marker and it looks great!
