question:what is the 'real' backspace of a rugged ridge wheel?
Old 02-19-2012, 04:56 AM
jerryb501's Avatar
Default question:what is the 'real' backspace of a rugged ridge wheel?
Here's my question:
The rugged ridge wheel shown on the rugged ridge site has following measurements:
17x9 with a 12mm offset which means this wheel has a backspace of 5.5, correct? (https://www.jk-forum.com/forums/show...do-they-relate)
Now why is this wheel advertised with a backspace of 4.75 ?
I am confused, can somebody explain please...
This is the wheel
Old 02-19-2012, 06:06 AM
kimp5756's Avatar
Default From Rugged Ridge
Originally Posted by jerryb501
Here's my question:
This is the wheel
Attachment 279680
Re: Backspacing?
Originally Posted by kimp5756
Quick question for ya...I'm really interested in your black satin wheels w/machined lip 17x9, what is the backspacing on this particular wheel?
And I did read correctly that these are hub-centric, right?
Thanks
Joe
Joe,
Yes the wheels are hub-centric, they were designed to fit the JK. The offset is +12mm which should make the backspacing 5.5".
Thank you,
Rugged Ridge
Rugged Ridge
forums@omix-ada.com
http://www.ruggedridgeoffroad.com
Old 02-19-2012, 06:21 AM
jerryb501's Avatar
Thank you for your quick answer.
Ready to order now...
Old 02-19-2012, 12:15 PM
Runewolf1973's Avatar
So why would they design a wheel specifically for the JK that you basically need to run spacers?
Old 02-19-2012, 12:37 PM
Mr. Smiley's Avatar
You don't need to run wheel spacers with this wheel.. I'm pretty sure the stock MOAB wheels are 7in of back spacing and with 1.5in wheel spacers that equates to 5.5in backspacing and it doesn't rub.. So you should be able to run this wheel with a 12.50in tire without any rubbing issues. But if your getting 35s your going to want I still trim your pinch seam in the back.
Old 02-19-2012, 12:50 PM
pcc999's Avatar
Old 02-19-2012, 12:54 PM
Mr. Smiley's Avatar
Originally Posted by pcc999
Wtf..... Chill with the dollar signs.
Old 02-19-2012, 04:11 PM
I thought the stock wheels had 6.25" of backspacing. If that's the case, a 1.5" wheel spacer should bring the new backspace to 4.75"....that's what I thought anyways. 5.5" just seems like a lot, but maybe I'm wrong.
Old 02-19-2012, 04:32 PM
Mr. Smiley's Avatar
I'm honestly not sure.. I coulda swore or ea somewhere on here that the stock wheels where 6.5-7in of BS.. But I'm not sure >.< hopefully someone with a 100% correct answer can chime in.
Old 02-19-2012, 04:33 PM
Mr. Smiley's Avatar
Yep.. Backspacing on stock wheels is 6.25in.. It's in the sticky *facepalm* I need to read more..
Quick Reply: question:what is the 'real' backspace of a rugged ridge wheel?
