Question for those with the Hypertech programmer?
I have read post after post on this and I just can't decide on what to do. So many people have had problems with these, that I'm a little leary about getting one. I want to get my speedo set right. I know it's an 11hp gain, but Alot of people don't think it was worth it. What I am wondering is are you happy with the programmer, or do you wish you would have got the Accu Pro instead, and made a gear change? I know Hypertech makes both these units. I'm just trying to figure out the best way to go about this.
Really the difference is on what your trying to accomplish.
I have the hypertech max energy and have been happy. The one most often missed point on using a programer, IMO, is that the ecu requires a lot of "training" time. So you wont see the total effect until after about 1100 miles. You will be able to set your gears and tire size ( measure the tires and don't go by the stated size) which will allow you rig to run properly and if its an auto will greatly help the engine shift at the correct times.
I have the Hypertech Max Energy and love it! I change the tire size, gears, fan temp, and use the Regular Power Programmer. Really notice a difference when I return it to stock. I don't feel as much difference when I try the Premium Power Programmer other than it hurts more at the pump.
I've programmed the Jeep and returned it to stock at least 20 times. Never a glitch.
If you have an auto, it is worth it to get the max energy to reset the shift points. If not... Well... you have already read everyone's opinions so I won't bore you with that all over again.
One of these weeks I am going to set mine back to stock for a few weeks to see if I can tell the difference. Either way, I will keep it for when I regear and add 35's, but it would be good to reconfirm my purchase. (or not)
It was worth it to me (at least in the sense of the difference between a cheaper calibrator and the Max Energy). Overall it's way too highly priced but I understand that the programming that goes into it is going to be very expensive.
I'm realistic and I knew what I was going to be getting. You cannot get much power out of a computer controlled engine without something radical. I was happy with the improved shifting and better throttle response (very happy with the latter).
I have had mine for several months now and the only problem I ran into was operator error, but once I got myself straightened out it worked fine.
