Question: on road ride
If you're still stock height there's not a whole lot you can do that I know of, except maybe try a different shock possibly. What specifically don't you like about it?
I personally liked how my Willys drove stock. My wife has a stock Willys and the ride is nice as well.
Maybe just let some air out of the tires.
Sponsoring Vendor
Feel
Maybe just let some air out of the tires.[/QUOTE]
As mentioned by others, Air pressure is a good place to start because it's FREE to do.
If you are lucky, that might make the feel tolerable without spending any money. :-)
The Willys should have a little stiffer ride than your previous Sport JK.
The Sport suspension and tires are soft and designed for the street.
The Rubicon suspension and tires (both of which you have) are heavy duty trail ready stuff. Stiffer sidewall tires and stiffer gas shocks are contributing to your "rough ride".
Like others said, try running a little less air pressure in your tires. I run 30 psi and it helps. At 35 psi, it feels a lot rougher.
